goodcooper
- Nov 4, 2005
so i just got 2x Monoprice 10509s http://www.monoprice.com/products/p...id=1130704&p_id=10509&seq=1&format=4#feedback
and i've been using them for a few days on VGA because i couldn't get the DVI to work on my x1900xt (figured it wouldn't do dual link for both of them or something)
so i just got a new GTX 650 in and hooked it all up, and i STILL can't get EITHER monitor to run on the DVI input!
i don't know what i'm missing! i have to use a VGA adapter and hook it up via VGA to the monitor, which of course gives me a crummy IQ...
i've never used a dual link display before so i don't know what the problem is!
i'm using the DVI cables that came with the monitors and they definitely have the middle pins... is there a setting i need to set somewhere in my graphics drivers? what's the deal?
EDIT: if i manually set the input on the monitor controls to DVI it just cuts off and then displays an "ATTENTION: No Video Input" message.... then a few seconds later it goes into standby (also just noticed the standby LED is out on one of the monitors :/ that threw me off at first)
