Okay long story short...
I recently installed a Scythe Ninja Rev. B on my s939 x2 3800.
Basically I was thinking of upgrading my rig, but decided to hold off a bit longer because the whole system is running fine, and I'm short of cash.
I was going to use the Ninja on my Quad setup, but since that won't be for a few months I did not want it to go to waste.
To say the least, I was not that impressed as my temperatures only dropped by about 5-6 degrees Celsius.
More importantly I wanted to overclock my x2 3800 since I now have more headroom.
I have tried everything from software overclockers, to BIOS tinkering. For some reason I cannot even get a slight overclock from stock speeds.
My board is no slouch, Asus A8n-E, and my ram is decent as well, Patriot DDR DC PC3200 2gb.
I found quite a few guides from [H] and online, as to what timings to use, and have set the multiplier to x10, as well as the HTT to 4.
Every result is the same, either my bios will freeze after IDE detection, or the bios will state that CPU Speed is o/c'd but CPU-Z reports nothing,
So I'm now wondering what processor (Socket 939) would be a worth, price competitive upgrade. Or any help as to what I'm doing wrong regarding OC'ing
Thanks [H]'ers
Fellows
Thanks [H]'ers
Fellows
