what am I doing wrong here ???
DisrupTer911
I just got a SATA WD3200JD drive.
I've isntalled it on Sata1 on my MSI K8N Neo2
windows recognized the drive as a removable storage device. but it does NOT show up under My computer or under Disk management.
I used teh windows xp pro disk to go in and create a 305gb partition on it thinking maybe then windows will see it as a drive.
Nope. Do I need to format it under the windows install disk? but won't it try to install xp on it when teh format finishes?
Do I need to install a SATA driver for a standalone harddrive?
I've enver had a single SATA hdd on this mobo, only my RAID array w/ the raptors and that required its only seperate RAID and SATA drivers.
how do I get it to show up? lol i'm brain farting hardcore here
my SATA Plextor PX716 SA dvd burner doesn't need a driver tho.
I'll have to get my hands on partition magic and see what I can find.
Any other ideas or suggestions?
Just wanted to post an update:
I got it working finally with teh help from a friend and his suggestions!
Originally, i'd get the RAID array on SATA 1/2. I later changed it to SATA 3/4 so that I could overclock the CPU.
Well, I never took the SATA RAID setting off SATA 1/2 in the BIOS.
Once I turned off the RAID setting on those ports, it worked first try.
Thanks for the help guys :)
