I have two computers in close proximity and they will be:
1. Core Duo 65nm & 8800GTX
2. Yorkfield 45nm & 9800GTX or 8800GTX
I would like to be able to cool both vid cards, both processors and the N/S bridges on each. Would that be doable in a single loop?
Figured the radiator would have to be something like this:
http://www.dangerden.com/store/product.php?productid=200&cat=85&page=1
Water Pump (might consider the pump above it)
https://www.dangerden.com/store/product.php?productid=38&cat=26&page=1
2 CPUs
https://www.dangerden.com/store/product.php?productid=291&cat=92&page=1
2 GPUs
https://www.dangerden.com/store/product.php?productid=257&cat=3&page=1
3 Fans:
https://www.dangerden.com/store/product.php?productid=283&cat=0&page=1
I figured 1/2inch tubing also.
If that is not doable lets focus on the 2nd system there. What all do I need:
I mean I know I need a block for each CPU/GPU/Bridge, but I see all sorts of add ons. Fill ports, resevoirs, fitings, varying types of fluid, etc. A little help with that would be wonderful.
I want the setup to be quiet. I was thinking 3 Yate Loons Medium or low. 28db vs 33, I mean 5db really going to be that noticeable?
Any suggestions.
Oh one reason i am thinking non-air is the fans are noisy and its getting increasingly difficult to get the dust off the fins. I figured I could mount the radiator and fans on top of my Antec Case and make it detachable so that I could service the loop without tearing apart the entire setup. IE Give the radator a good shot of compressed air and if need be take it to the sink and scrub the bastard!
Thanks for all your input! I'm hoping to buy and install this setup on my 65nm duo & GTX now and have enough room to add my future 45nm quad core & 9800GTX into the loop at that time.
2 CPUs
2 GPUs
3 Fans:
Any suggestions.
