What air cooling for 3000+ Skt A?
Aelfgeft
Since my other thread failed miserably, I will now ashamedly try again.
Having discovered that I can't use the glorious XP90 or 120 with my new XP 3000+ (not 64) I need suggestions for good air cooling solutions.
IMPORTANT: Noise is not an issue. I have high velocity fans in my apartment running all the time. I want maximum cooling from what I use, with nothing sacrificed for silence.
The SI-97 is socket A right? I don't think you can do much better than that for air cooling.
Tornado fans are extremely high in their cfm and dDA ratings. There are also high flow high noise Panaflo fans. Check out delta fans too.
Just look at all those fans dDA and cfm ratings and pick the highest cfm!
Thanks Russ!
The SI-97 looks ideal in that is is lightweight as well as a good cooler!
The only place that seems to offer it on pricewatch also offers a 119CFM Tornado fan, so that's probably what I'll get to accompany it. Looks great :)
