Sorry but I'm just going to admit I don't know that much about processors. I'm also thinking of moving over from amd to get a core2duo, so can someone help me out? I'm not planning to overclock, so what factors should be my biggest concern/s? A few years ago I just considered the mhz, but now obviously there's a lot more to choose from...
As an example, oblivion says they recommend a 3 ghz pentium 4 'or equivalent'. well, does that mean that a core2duo E6300, which is 1.86ghz, isn't going to cut it?
How much of a performance difference will there be between the E6300 (1.86ghz) and the E6400 (2.13 ghz) ? The rest of their specs appear to be the same (fsb, nm, cache)
I'm basically just focused on performance in games, as it will be primarily used for games.
