i need a $500 build and i want to run aion and rift on medium settings with 60 fps
The whole computer or just a video card?
does your graphic determine how much fps you get?
i want to get 60fps on aion and rift on medium settings
what type of gpus do i need
Not possible. I played with a 4.5ghz i7 2600k + gtx 780 1250mhz. Got drops to 15fps in certain places.
The game is absolutely horribly optimized. It just doesn't use resources. my gpu wasn't at 100% and neither was my CPU and it just ran like shit.
this is really in the wrong place, and lacking a lot of info
like - do you have a monitor? a legit windows key? any parts to reuse?
do i need a stronger gpu? like the 790?
If your budget is $500, you wont be able to afford the GTX 790 (if it even comes out...)
That card alone is rumored to be over $1000.
i know im stupid i thought 790 was already out
so 780 ti is the best gpu
titan is not worth it for the money?
