What additive to use?
PawNtheSandman
I have a zalman reserator. It says use distilled water, with a mold exhibitor.
Do you think I should go with
Water Wetter
yellow antifreeze
dex cool (I need some for my truck anyway)
or something else
Let me know what you think would work best.
I was using Zerex for a while, and a little bit of algae started to grow after a couple months. Since I've been using antifreeze I haven't had a problem.
Isn't it like 10% to 15% antifreeze and then distilled water? That should keep everything protected and clean from algae and crap right?
I use 10% mixture of Low Tox Anitfreeze (Propylene Glycol). I haven't had any problems with anything growing in any of my systems.
