What about PROJECTORS?
A big factor in that decission is whether you have enough money to use them for gaming.
Just consider that depending on how often you use the projector you are going to be looking at reasonably frequent bulb changes at over $100 per.
I use my FP for gaming, but the above poster has a point - the estimated bulb life for mine is 3000-4000 hours. Also you have to have very good light control in the room you'll be using the FP in. In terms of it working and being enjoyable, it does work and is very enjoyable. If you don't mind the bulb replacement costs and and can keep the room dark it's definitely doable. Doom 3 looks awesome @ 110 inches :D
