What 19" CTR too get?
SolidFeather
Hi, I'm looking for a 19" flat CTR monitor and I think that I have narrowed it too this 3 monitors
Hansol 930D: http://www.hansol.ca/monitors/930D.htm
CTX Executive Line EX951F+: http://www.tb.is/?gluggi=vara&vara=4629
Maybe this one; Samtron 96P; http://www.task.is/?webID=1&p=182&sp=222&ssp=223&item=675 alhough I don't think it's flat.
The reason I chose this monitors is 'coz they're cheap. So, wich one do you guys recommend?
//EDIT: I was offered this one http://www.hansol-us.com/products/product-pages/920D.html
used and 3 years old for cheap. Is it any good?
Well, to be honest, the ones you listed are crap. The other guys were just trying to suggest others in a similar price range that would be better. Look around, Viewsonic is a large manufacture, as is NEC/Mitsuishi, the latter especially in Europe i think (which is what iceland is a part of, right?).
im looking for a crt too, how about we post newegg links and list the model so the guy can see if their avalible in iceland
