Wha...?
Mr. Pedantic
Take a look at this:
Code:
--- Opening Log file [June 17 17:58:58 UTC]
# Windows SMP Console Edition #################################################
                       Folding@Home Client Version 6.29
                          http://folding.stanford.edu
Launch directory: C:\Program Files\FAH\WinSMP
Executable: C:\Program Files\FAH\WinSMP\FAH.exe
Arguments: -smp 7 -verbosity 9 -forceasm -local -advmethods -bigadv
[17:58:58] - Ask before connecting: No
[17:58:58] - User name: Mr._Pedantic (Team 33)
[17:58:58] - User ID: 508DC76E16C08206
[17:58:58] - Machine ID: 1
[17:58:58]
[17:58:58] Loaded queue successfully.
[17:58:58]
[17:58:58] - Autosending finished units... [June 17 17:58:58 UTC]
[17:58:58] + Processing work unit
[17:58:58] Trying to send all finished work units
[17:58:58] Core required: FahCore_a3.exe
[17:58:58] + No unsent completed units remaining.
[17:58:58] - Autosend completed
[17:58:58] Core found.
[17:58:58] Working on queue slot 09 [June 17 17:58:58 UTC]
[17:58:58] + Working ...
[17:58:58] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 09 -np 7 -checkpoint 3 -forceasm -verbose -lifeline 2116 -version 629'
[17:58:58]
[17:58:58] *------------------------------*
[17:58:58] Folding@Home Gromacs SMP Core
[17:58:58] Version 2.19 (Mar 12, 2010)
[17:58:58]
[17:58:58] Preparing to commence simulation
[17:58:58] - Ensuring status. Please wait.
[17:59:08] - Assembly optimizations manually forced on.
[17:59:08] - Not checking prior termination.
[17:59:09] - Expanded 4300945 -> 10427873 (decompressed 242.4 percent)
[17:59:09] Called DecompressByteArray: compressed_data_size=4300945 data_size=10427873, decompressed_data_size=10427873 diff=0
[17:59:09] - Digital signature verified
[17:59:09]
[17:59:09] Project: 6013 (Run 0, Clone 89, Gen 176)
[17:59:09]
[17:59:09] Assembly optimizations on if available.
[17:59:09] Entering M.D.
[17:59:15] Using Gromacs checkpoints
[17:59:18] Resuming from checkpoint
[17:59:18] Verified work/wudata_09.log
[17:59:18] Verified work/wudata_09.trr
[17:59:18] Verified work/wudata_09.xtc
[17:59:18] Verified work/wudata_09.edr
[17:59:19] Completed 56966 out of 250000 steps  (22%)
[17:59:58] Killing all core threads
[17:59:58] Killing 2 cores
[17:59:58] Killing core 0
[17:59:58] Killing core 1
Folding@Home Client Shutdown at user request.
[17:59:58] ***** Got a SIGTERM signal (2)
Folding@Home Client Shutdown.
--- Opening Log file [June 17 19:32:40 UTC]
[19:32:40] - Ask before connecting: No
[19:32:40] - User name: Mr._Pedantic (Team 33)
[19:32:40] - User ID: 508DC76E16C08206
[19:32:40] - Machine ID: 1
[19:32:40]
[19:32:40] Loaded queue successfully.
[19:32:40]
[19:32:40] - Autosending finished units... [June 17 19:32:40 UTC]
[19:32:40] + Processing work unit
[19:32:40] Trying to send all finished work units
[19:32:40] Core required: FahCore_a3.exe
[19:32:40] + No unsent completed units remaining.
[19:32:40] - Autosend completed
[19:32:40] Core found.
[19:32:40] Working on queue slot 09 [June 17 19:32:40 UTC]
[19:32:40] + Working ...
[19:32:40] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 09 -np 7 -checkpoint 3 -forceasm -verbose -lifeline 504 -version 629'
[19:32:40]
[19:32:40] *------------------------------*
[19:32:40] Folding@Home Gromacs SMP Core
[19:32:40] Version 2.19 (Mar 12, 2010)
[19:32:40]
[19:32:40] Preparing to commence simulation
[19:32:40] - Assembly optimizations manually forced on.
[19:32:40] - Not checking prior termination.
[19:32:41] - Expanded 4300945 -> 10427873 (decompressed 242.4 percent)
[19:32:41] Called DecompressByteArray: compressed_data_size=4300945 data_size=10427873, decompressed_data_size=10427873 diff=0
[19:32:41] - Digital signature verified
[19:32:41]
[19:32:41] Project: 6013 (Run 0, Clone 89, Gen 176)
[19:32:41]
[19:32:41] Assembly optimizations on if available.
[19:32:41] Entering M.D.
[19:32:47] Using Gromacs checkpoints
[19:32:50] Resuming from checkpoint
[19:32:50] Verified work/wudata_09.log
[19:32:50] Verified work/wudata_09.trr
[19:32:50] Verified work/wudata_09.xtc
[19:32:50] Verified work/wudata_09.edr
[19:32:50] Completed 110766 out of 250000 steps  (44%)
What I did was I turned my computer on, started the client, and then went to services.msc, shut down the client manually, then started the service. Then afterwards, I shut down the service, and restarted the client manually, producing what you see here. This is a direct copy/paste from the log, there's been nothing added, deleted, or moved. There was no extra portion in between the two starts indicated in the part I put in the code tags. The client was using CPU utilization in the Task Manager, but its progress wasn't showing up on HFM, so I stopped the service and restarted it. And it appears that this is why: the progress wasn't logged. Roughly 90 minutes of runtime wasn't written to the file. This happened with my GPU client as well, it appears that there must have been a corrupted checkpoint and it restarted. So what's going on? Why didn't it write? When I used services to start the client automatically in the past it wrote to the log file, why didn't it do it this time round?
I've seen this once or twice before. Really tripped me out, but at the end of the day, it finished and was sent up. Don't know what to tell you. You could delete and restart if you are concerned with the validity of the results.
I'm just wondering why the log isn't recording all the activity that's going on. What's the point of a log, if it doesn't write everything down?
ive had it happen before.. but i dont care enough about the log anyways since the winsmp clients so much more stable then it was before..
