Westy 32H240S - Help
hi there
I bought this 32" Westy a few months ago and never had a problem, very pleased overall considering price.
BUT ... for a few weeks now I've been having some issues when the TV is turned On after being off for the night - I get a very hard pixelation, really, but really choppy. Sometimes it goes away a few minutes later just like that and sometimes is takes a little On/Off interaction :).
Since English is not my first language I'm including pictures so you can appreciate what my lack of vocabulary could explain better.
I have a DirectTV HD Receiver connected by HDMI cable (good quality) and I've narrowed down my options to the TV since I have another SD receiver in a regular TV and I don't get that never, so I'm assuming is not bad reception or somethign like that.
Don't break your head trying to solve this, basically what I'm looking for is for some similar experiences and just make sure I don't become crazy or start using some "persuasion" anytime soon.
Thanks in advance
Carlos
hey there
it keeps doing the same, but now I really isolate the problem to the TV itself, no Directv receiver to blame, it flicker even when using the xbox360
I bought it no more than 5months ago at BestBuy and didn't get any extended protection plan - what would you advice in order to get this TV fixed/replaced ? just take it there with the receipt and box or should I have to contact the manufacturer ?
please give me a hand here, I never had to claim nothing before
thanks in advance
I believe you bring it to best buy and they package and ship it back to, and then they repair the TV.
