Westinghouse LVm-42w2 problems with ps3...SOMEONE PLEASE HELP!!!
1)with component cables(problem with the screen being very pink but sharp)
sooo I went out and bought an hdmi...
at first it wasnt recognizing it at all the signal at all...so i got it set up with a normal av cable....then switched to hdmi once it started working.....(butttttt it started blinking between working and not working)
since its been switched...whenever im in the media bar in 1080p it works then goes blank...ever like second and a half second..then works for a second...
....once i start up resistence or motostorm demo it works perfectly fine...but only if i restart my ps3....then...when i go back to the menu...it blinks again......same thing with blueray movies....it blinks over and over again...
so to review...if i start it up it work sfine usually....ill go play a game and it works fine....the moment i go back to the media bar system thing...it starts blinking...anddoesnt ever stop.
i believe my firmware is 1.0 on my westy....
ooo just to let you guys know my 360 work sfine in all my component outs, and vga outs.
ps- my powerbook can use it as a monitor at 1080p no problem at all
