Westinghouse 42w2 problem...
Bowhuntr11
Alright so my 4207 has a problem now...
I pushed the guide button for my satellite and my screen went black, but I could still hear sound. So I guessed that it was the video cord...so I checked the video cable unhooked it and hooked it back up and nothing...So then I turn it on and off, still nothing...
So I then get the remote and try to switch inputs, and I can hear it switch inputs, but I don't see it showing the input in the upper corner. So I turn on the 360, and I can hear it...but no picture.
I pushed menu on the remote...nothing. :(
The backlight is On...as I can see light coming from it. Just no picture.
So any ideas?
please? Still having the issue, called westinghouse and they weren't any help...
Correct... Component, Regular Video, I guess I might try VGA/DVI or something and see if I can get some sort of signal..
Bowhuntr11-
Do you have a DVR Box?
Do you have any shows saved?
Trying hit the button to watch previously recorded show. Then click play to watch a previous recording and let it run for a minute and then EXIT.
This should take the screen back to normal
Thanks
Jon
