I currently have my Westinghouse 42" 1080 connected to a computer and I am having the following issues.
1. I have the monitor connected to DVI 1 with a ATI 1650 512mb card and whenever I restart the computer or change resolutions in a game, the screen comes back totally scrambled. Through about 4 days of trial and error I discovered that turning the display off then on again is the only surefire fix. Has anyone else with either the 37 or 42 come across this? I have the three year extended warranty with crutchfield, is this something I should consider or just brush off as a minor annoyance?
2. When I connect with DVI 2, the image is shifted upwards by a few pixels. I get a bar of blackness at the bottom and my mouse dissapears at the top of the screen. I have a new computer arriving on monday so I plan to use both DVI connections. Is this something powerstrip can fix? It happens with both my roommates computers as well (both core 2 duo, one 7950 and one 8800).
Thanks.
AngryJim
Thanks.
AngryJim
