hi
i have a WD15EADS-00P8B0
it has a problem (some files damaged)
i want update firmware
but cant found any software and firmware files
what should i do
If you want to recover files, use recovery programs
Updating firmware doesn't really work on HDDs; as the firmware has to be made explicitly for your model. Firmware made for other chips is not compatible. Updating firmware on HDDs is very rare.
Why don't you tell us more about the damaged files; if recovering them is your objective.
If the drive has bad sectors and you still have warranty, you should return the HDD not attempt to repair it yourself. Just get your files off and send it back to WD.
