Werid freezing problem
killerasp
my computer has been going nuts for the last couple of weeks. i basically isolated the problem to my hardware (ram, mobo or PSU)
The thing is, it sometimes boots. When i mean sometimes, it sometimes goes to a black screen and hangs after post. Sometimes it hangs during the WinXP animation during boot. Sometimes ill get in then it will freeze during "welcome" screen. When im finally able to get into windows, it might frezze when i try to open up browse my hard drive. its just likes to freeze at random places.
I changed out the hard drives with new ones, i changed IDE cables, i reformmated and nothing.
The only thing i havent tried is changing my mobo, PSU and or ram.
Jesus crist...someone please help me. its really becoming a PAIN IN THE ASS.
did you plug in your hard drive or dvd burner the right way that could be the problem. You should also put some compund on your cpu and gpu from best buy store its the best stuff ever made in the world. Or get a 250 watt psu they have lots of power and can fix the problem. Last i would put in 128 mb of ram because its alot and can change any problem you have at all.
thevampirelord66 said:
run memtest86
let it loop for about 7 times and if it has errors than its definitly ur ram
ran it 10 times...no problems. back to square one.
