MysticMooseBB
- Jan 30, 2005
I have a Linksys / Comcast Wcg200 cable modem / switch / wap.
I have a couple questions about WEP 128bit.
First off, is there a limit to how many computers / clients can use 'Key 1' on WEP 128? When I try to generate a WEP key in 128 mode, it only creates one key- however if you do it in 64bit mode, it creates 4 separate keys.
I am trying to get three computers to use WEP 128bit, but it seems I can only get 2/3 computers to connect.
The main problem I have is actually a DHCP error. The last machine I try to connect (with the proper key / pass phrase) only gets the 169.254 IP instead of a 192.168.x.x. I called Comcast tech support, but they basically just said to use MAC filtering (which I already have turned on).
A follow up question comes by the equipment I have, the damn 3-1 box from Comcast. I can't seem to find it listed anywhere on Linksys's website for updates for firmware. Are firmware updates even legal on a Comcast supplied box?
Disclaimer: I am aware WEP is not very secure, and plan to eventually buy a WPA access point and have the machines go through there- it just might require some time.
Thanks in advance,
Moose
Thanks in advance,
Moose
