WEP-M+2 Project
pututu
[H]ard DC'er of the Year 2021
Trying to create an account for this project but the captcha thing is being shutdown.
Any idea? Thanks.
They may have to update their site.... I've seen posts elsewhere of this happening.
In the meantime, you can always use the test account by:
This key can be used to:
  • to attach a computer to your account without using the BOINC Manager. To do so, install BOINC, create a file named account_bearnol.is-a-geek.com_wanless2.xml in the BOINC data directory, and set its contents to:
    <account>
    <master_url>http://bearnol.is-a-geek.com/wanless2/</master_url>
    <authenticator>8191_d522bd40d2764664d6f9d3f02285f12f</authenticator>
    </account>
I'm trying to attach projects that I've not yet contributed. I guess I'll have to sit this out and hopefully they will fix their website for new account creation in a distant future.
Since this project is in FB sprint list, the above will be handy when the time comes.
Just curious, were you also not able to create the account via BAM!?
Thanks. It works in BAM!
To be honest, I used BAM! when I first started but never continue to use it. Thought that I would only run a few projects back then :D
Glad to hear that it is a work around. This project isn't popular for multiple reasons and so I'm doubting anyone has reported due to those reasons as well...
