Diesel-man3000
- Jun 25, 2007
Ok some of you guys might remember a few of my post before about me e521 and my grief,but this time i got mostly good new.I decided to make do with what i got right now .I think i will hold off on case and motherboard untill i decide to build a whole new pc,maybe.
My first specs were a 3800x2,1gig ram 5300,integrated graphics 6150,and vista premium evyrhthing else was pretty bare.MY current setup is now a 3800x2,2 gigsof ram couples with my previous ram running at the lower speeds,i also just got a 7900gs.I think i should be able to play every game at max right now on my current lcd res which is 1280-1024.
My only problems at the moment are that after i installed the card,my psu didn't have long enough reach and doesn't have a 6 pin pci-ex connector,so i decided to power the comp up for a second to see whether the card would start and it did.So i went on and started the comp again and then windows recognized it and installed the update,it was a older driver so i went to evgas site and installed the lastest vista one.Evrything feels pretty cool at the moment i actually think the card makes my case cooler from the touch.anyways i ordered the thermaltake connector a guy said he used on his e521 for the same video card.
So i just want to know what you gus think and do you think this will do for a lil while.
my 3dmark06 score was 4437. i know its pretty low but i think i might try ocing the video card lil bit.
