Weirdest problem ever in a viewsonic VX2035wm
TheDarkTao
Ok, I was just sitting there playing warcraft III... :) .... But no :eek: I alt tab out for a moment, and my desktop is in 640x480???:confused: So I go into graphic settings and try and fix it, set it back to natice 1680x1050... And the monitor conks out... blank screen :(
So I restart, noticing that it went up to some extremely high number like 2580x something, and thinking maybe I accidentally click too high... So I restart, and sure enough it works. The vista little green scroll bar even loads, but as soon as vista starts, again blank... So i try safe mode, and it works. So I go back into regular mode, and still nothing.
Ok, then I try swaping cables (having a bad DVI port on another video card, I thought that could be it) Well here is the kicker. It was in fact 1680x1050 and it was something wrong. Now my monitor only works if I hook it up analog, but I can use the DVI port and convert to analog with an adaptor. I tryed another monitor and same thing.
So the question. Why is it that high (native) resolution will not work, why will it load and all but soon as I get into vista it does not work. Could it be a faulty video card (both ports same problem) or is it a faulty monitor....
Ok I know this is a hard question, and if you have any suggestions or questions... Help is SO MUCH APPRECIATED :D :D I want DVI back :(
