Hey guys, trying to fix the family computer on my christmas visit home, I've fixed most of the problems, but there is a weird bug I am encountering with the wireless access that this the computer in question uses.
For some reason it keeps picking up a really weird ip address when it boots up (169.254.57.109, subnet 255.255.0.0), it should be getting a 192.168.0.x address with subnet of 255.255.255.x. I have tested this network with my own laptop that has wireless and have no troubles connecting to it. I have also triple checked that it is using the correct WEP-key, ESSID, and on the correct channel. This computer uses win2k and has a netgear ma311 wireless nic. It doesn't seem like win2k has the same support for wireless that XP has, so I am using the included program from netgear to set all the settings. Also of note, if you go and run ipconfig from the command line, and try to release the funky IP, it says it was automatically configured and cannot be dropped by /release. If anyone has some good ideas on how to fix this problem it would be greatly appreciated as I am stumped at the moment.
Thanks in advance.
Thanks in advance.
