First and foremost I'm no expert. I know enough to be dangerous and that's about it. This thread is inquiring about CPU, RAM, Mobo, and PSU voltages... I couldn't find a better place for the thread so mods please move if you see fit.
These voltages may very well have been this way since I built my computer a year ago or so, but I haven't ever checked until recently. I picked up a CM 212+ to keep my CPU cool while folding (for Team 33 of course) and when I installed it, there was a ton of headroom so I decided to OC. I'm currently at 4.4 GHz at around 1.28V... I think.
Here are the voltages of concern:
CPU Voltage is set to 1.36V in the BIOS, but CPUZ is showing Vcore is 1.272V. I'm assuming Control Center is setting VID and CPUZ is showing Vcore. Someone correct me if I'm wrong. Either way I think these voltages are within acceptable ranges for 24/7, but depending on which is the one to watch, I may have a lot more room to keep going up.
VCC3V: 3.36V (is +12% ok?)
DRAM Voltage: 1.5055 V, but Vdimm in SpeedFan is 2.21V
Are these two points different?
VCC1.5V: 0.74V (is -50% ok?)
VSB3V: 3.23V (is +8% ok?)
+12V: 10.38V (seems really low @ -14%)
I have speculations about some of these, but I wanted to hear it from you first. Any help is appreciated. System specs and screenshot below. Thanks!
MSi Z68A-GD65 G3 mobo, bios version in screenshot
OCZ550FTY - "550W" PSU
i5 2500k @ 4.4GHz, 1.28V
8GB, 2 dimms DDR3-1333 RAM - 1.5V, attempted to run at 1600, not sure if my dumb BIOS kept that setting though...
MSi R6870 Hawk
1x SSD
1x SATA spinner HDD
2x IDE spinner HDD's
1x SATA DVD burner
Other random peripherals - PCI Audigy 2 ZS, cheapo IDE controller card.
8 case fans.
MSi R6870 Hawk
1x SSD
1x SATA spinner HDD
1x SATA DVD burner
8 case fans.
