Weird voltage rails and temp readings...
ShogunCS
Hey guys, I have the OCZ Powerstream 520w psu and the volts are not good. According to MBM 5 the 3v rail is at 3.26v the 5v rail is at 5.03v and the 12v rail is terrible at 10.88v! I tried to adjust the rails with the pots but when I turn up the pot for the 12v rail the LED goes red indicating that I'm overvolting and the screen goes haywire! Could this possibly be just the software reading this wrong or is it a bad psu? Also, my temps seem strange, my CPU diode temp is 10 degrees celsius, 47 degrees socket and 36 degrees system temp. I have watercooling on this rig and my temps are this high? I'm starting to think that MBM 5 is bugged because I did select the correct motherboard setting (DFI Lanparty Ultra B). Any idea guys?
Have you tried checking your voltages in your bios??? Check those and compare them to the voltages in MBM5 that would give you a better idea. The funny thing about reading the voltages on the rails through software is that they may not be entirely accurate. The reason for this is being that the motherboard/software is getting its readings from the voltage regulators on the motherboard. This being said it could be a problem with your motherboard rather than the PSU. just to be safe you can check all your rails on your power supply manually with a voltmeter and a little bit of time.
Do you have a multimeter? Do any of your mates? If so, turn the pc on, set it to voltage and put it across a molex connector, (yellow and a black) that will tell you the actual twelve volt, then across the red and black to get the 5 volt. The 3.3V is trickier, but doable. Turn of your box and unplug the atx connector, use a paper clip/piece of metal, to short the green wire to a ground (black), and then measure teh 3.3V by putting your meter between an orange wire and ground. I had to do all that when i noticed my board was reading my 3.3V rail at 2.7V a while ago, but it was fine.
