I'm having an incredibly weird problem with framerates.
Machine:
Vista Ultimate x64
Asus P6T v2 Deluxe (latest bios)
4 GB DDR3 (dual channel setup atm)
Intel i7 920
dual 9800GTX+ GPUs w/ 190.62 drivers
Problem
I run EVE-Online in two clients, windowed mode. I run one per monitor. This machine is beasty enough to run both premium clients at 60FPS constant (EVE limit) with no problems, however it is exhibiting very odd behavior. It will run both at 60 for a bit, then inevitably slow both down to 1/2 speed. If I minimize one, the other goes back to 60. With both up again, it will immediately drop. The WEIRD thing is that if I have both up, and put a NEW window (notepad, anything) over one of the clients, and then HOLD the mouse down on the title bar -- both clients immediately push up to 60FPS and stay there. As long as I have the mouse clicked (held down) on notepad and move it around, the two EVE clients go to full speed. If I left go, they drop.
I've tried this in SLI, non-SLI, multimonitor performance. The other odd thing about it is that if I let both clients just sit there and run at 30 for a while, about every 5 seconds they push up to 60 fps and then immediately drop back down.
This isn't a performance issue--the pc can handle everything w/ many cycles to spare... so this is just killing me. Any help is appreciated.
Machine:
Vista Ultimate x64
Intel i7 920
Problem
