Weird Video Issue with 775 board
foozy
I have an Intel DP35DPM motherboard. I purchased an ASUS R9 290 video card for it. Video hangs at the bios and shows 5A at the bottom right of the screen. I have tried using the bios switch, with no luck.
Weird thing is, I have another one of these boards with a Sapphire R9 290, and it works completely fine.
Each system has Intel Celeron 430, 4GB DDR2 and a CX750M.
Any help would be greatly appreciated. Thank you.
What's the manual say status code 5A is?
Try the sapphire card in the 'problem' mobo yet (and the asus 290 in the 'working' setup)? Check that so we can quickly rule in/out a bad graphics card.
Also make sure to double/triple check that everything (power, vga, ram, monitor connection, etc) is properly connected and fully seated.
Let us know and, if you don't find the problem with those checks, we can start trying other stuff.
Thank you for responding.
POST code 5A means "Resetting PATA/SATA bus and all devices"
The Sapphire video card works in both motherboards. The ASUS does not. Same exact specs. The ASUS one works in a z68 motherboard.
Try a full bios reset?
Weird...so both cards definitely seem to work. Haven't researched them but is there any difference between the sapphire and asus you can find anywhere?
Was going to suggest pulling the cpu and checking to make sure you don't have any bent pins in the socket. If it's easy for you...might be worth a look just to make sure?
Mobo seems fine, vga card seem fine. Did you try pulling then re-seating the asus card (sounds like you did already)? Weird that the sapphire works in both (identical) mobos but the asus doesn't work in either (which is why I wonder if there's any underlying difference between the cards).
Maybe try uninstalling all video drivers while the sapphire's in there, reboot, confirm there are no files left, power down, install the asus, start up and then re-install the graphic drivers from scratch?
Sorry I can't be more helpful....kinda scratching my head atm
I'd try using different power connectors and see if that changes anything. Also check to see what the voltage is at the PCI-e lane (over/under-clocked). Maybe something is messed up that one card can handle, but the other cant (possible that one card is stronger than the other)
Do they both use the same GPU power connectors? Or are they different between brands?
If you plug the card in without auxiliary power, what happens? Can you flash the bios on the Asus card (back it up first) to the Bios on the other card?
The standard Sapphire Bios for the 290 is not UEFI, the standard bios for the Asus IS UEFI. Have you tried switching the dual bios switch on the Asus?
Are you saying the ASUS GPU BIOS is a UEFI? That's one I'm not familiar with.
New MBs yes, I wasn't at all aware that GPUs has gone to UEFI BIOS.
I think from reading this is merely a quirk.
The Sapphire card works fine with both MBs, so it's not a PCI-e issue or a connection issue.
The ASUS card works in the other MB of the same kind.
My only question is why are you using such a high powered GPU in an old-ass MB?
Mining?
That's exactly what I'm saying. I'm not sure if a non-UEFI MB can be used with a UEFI Video Card
Confirming that an XFX R9 290 works fine.
Jorona, if the XFX is non uefi, seems like you may be right. Appreciate all the input gentleman.
This is kinda odd but I'm having the same issue just with a gigabyte r9 270 oc and a Intel DX38bt. If I have the 270 in slot one I either get 5a or that 99% of the system memory passed and the system locks up. I have an hd4850 and that works just fine. I had the hd4850 in slot one and the 270s in slot 2 and 3 and it would boot up and recognize the cards but never initialize them. Oddly enough I put the cards in an even older 915 board and they work just fine in that(yes it is for mining in my case).
I had the same issue to with my 270. Did not work on this board.
