Weird USB 3.0 problem I had.
cyclone3d
The other day I went to use a USB stick in one of my USB 3 ports and Windows would not pick it up.
I tried every USB 3 port on my board and nothing.
So then I went and looked online and found that other people who were running Windows 8 and 8.1 were having the same sort of problem with the same USB 3 controller I have, which is an ASMedia.
I tried everything suggested from upgrading the USB controller firmware to trying the latest drivers to trying Renaesus USB drivers. Nothing helped.
I even did a scratch install of Windows 8.1.
I did notice at one point that Windows was saying that the USB controller was failing to start, but got that resolved after re-installing the drivers, but the ports were still not working.
I thought about putting Windows 7 on a spare drive to see if that would fix it, but it had been working fine on Windows 8.1 for quite a while.
I then decided to reset my BIOS on the off chance that something was screwed up even though I hadn't changed any settings for quite a while before it started messing up.
Booted back up after resetting the BIOS and it worked.
I then set my settings back to what they were previously and it is still working.
I was about ready to pull my hair out and RMA the board.
Ditto. I have the above exact same problem on my Asus motherboard on my windows 7 Professional, 64 bit w/ SP1.
It starts when my USB keyboard light is fading out, ie., the PC doesn't see the USB keyboard.
So I try other USB port at the back of the PC, same thing.
Then the other day, when I push my CF card USB 3.0 reader to my front port of my case, on the USB 3.0 port, windows 7 is not picking up the CF card reader.
So I push it in to my USB 2.0 front port, windows 7 see it, but moments later, my keyboard fades out again.
Then what I did is, on my USB 2.0 keyboard, it has 2 x USB port, 1 is for power only. I bought 1 of those USB to electrical wall plug toy, and plug the USB port directly to the power bar.
Do you have any device that requires USB power?
Now, as to your tricks, when you said reset the BIOS, you mean:
i) Load the default value of your BIOS?
OR
ii) download an older BIOS
Also, since when is there a USB controller firmware from Asus?
Now, I talk to my sources on this: Win 7 (And most likely win 8) has Microsoft build in USB 2.0 driver. Win 7 does NOT have USB 3.0 driver. USB 3.0 port is made by only 2 to 3 co., Intel and ?? and ??
So 1 trick to remember is: Never connect a USB 2.0 device to a USB 3.0 port. But in my case, my device is USB 3.0, and it was working for months. on this brand new PC, put together by me in christmas.
P.S. could you post an update IF it doesn't work in the future. Like you, I was about to RMA the motherboard.
I have also had this problem about a half dozen times in the last year. As with you it was the asmedia USB 3.0 controller on a Asus mobo running Win 7 Ultimate 64 bit. All I have to do is reboot the computer and the ports work again. Probably need a firmware upgrade to fix, but Asus has yet to issue!
exactly, it's not a motherboard failure, so RMA won't fix it. For e.g., the most recent incident when I insert that CF card on the USB 3.0 front slot of the PC, CAUSES my USB 2.0 keyboard to fade out immediately after. These are clearly bugs.
Cyclone3D, please re-post in 2 mth. time if your trick really works. And I'll do the same. I have to say, my USB to power plug trick is quite creative.
Similar issue. Drove me nuts for a day...twice. Both times I thought my USB keyboard had died. It was the USB drivers in my w7/64. Asus mobo.
No problems for several months...
@Happy_Hopping
I reset the BIOS back to default settings with the reset button.
Also, ASUS and ASROCK do not officially have a firmware update for the ASMEDIA USB controller. I had to download it from a 3rd party. The same for the latest driver.
Here is the page where you can download them from. This site does auto open up full screen browser window for ads every time a page changes, but it was the only place I could find the updated firmware and drivers.
http://www.station-drivers.com/index.php/downloads/Drivers/Asmedia/Chipsets/ASM1041-ASM1042-107x-USB3-Controllers/
The firmware has to be installed via a DOS boot disk.
