Weird triangles in 3d games??? Where is the problem??
Kryogen
Friend of I says that when playing 3d games, he sees big triangles, and everything fu***s up. It doesn't do it all the time.
The pc has been allright for a while and it suddently started doing this.
I believe it could be an heat issue, but um, it's a geforce 3 ti-200, not overclocked, with a crystal orb, heatsinks on the memory, and there are 2 case fans. Why would it overheat.
Could it be a driver issue? He's been having spyware trouble recently.
Any ideas? Check GPU temps, reinstall drivers, reinstall DX9, anything else? ieas?
Thx
it could be dust buildup
or old, dying capacitors.
Your best bet is a new card.
