Weird Temperature Problem
KDKHAN
Guys look at the following screenshots. They show the specs and different temperaturs of my system. I have not used this processor (e8200) for quite some time.
Today I build an LGA775 system and temperators of the system surprized me.
The softwares in windows showing very high temperature while bios shows negative / minus temperature.
I applied thermal paste afresh and even replaced HSF but of no use. Cleared CMOS but a futile exercise.
There is only 1 version of bios available on the Asus website and its alraedy flashed on my system.
Please look on screenshots and offer your valueable and expert views in the matter :
Something wrong with temperature sensors. I guess you going to have to live with it as long as it works.
If the motherboard has a jumper or switch for sub-zero, make sure it's set to off.
Reseat your CPU, you are probably not getting good contact between the CPU and heat sink / water block.
Use a premium TIM
recheck
:D
