So I just installed my Corsair H60 water cooling unit and I'm getting some crazy temperatures. After a half hour playing Starcraft II Speedfan tells me that my CPU is at 68C. Coretemp won't give me a temp for my CPU.
Right now Speedfan tells me my CPU is idling at around 51C. That's several degrees higher than the stock HSF.
When I go into my BIOS and check on Hardware Health, it gives me 24C for my CPU temp. That's more like it, but now I don't know which is wrong and which is right because 24C is very low. Anyone know of another utility that gets accurate temps? The only other thing I can think of is that something is wrong with my H60. I can hear the pump running (I think), but I kind of screwed up the thermal paste I think. Could that be causing the supposedly super high temps?
And is it correct to have my fan blowing INTO the radiator? Sorry if this should go in Water Cooling forum but I think its a hardware monitoring issue
