Friend of mine has been having some bad stability trouble lately.
First the system spec:
PD @ stock clock (3.0GHz)
3GB Corsair (2x1GB of 6400C4, 2x512MB of 5400C4, all running at 667MHz, 2.1v, 5-5-5)
Abit AW8
Generic (aspire?) 420W psu
XFX 7600 GT (stock clocks)
He's owned the box for 2 years, since initially built, with the stability trouble only arising recently, in the last 2 weeks. He can be playing WoW or surfing the web when without warning, the box will restart.
He and I have been going around trying to figure this out... we've tried upping CPU volts, DRAM volts and NB volts, all seemingly to no avail.
He ran memtest continuously for about 6 hours with no errors at all.
I had him download Orthos today and try it out. His CPU will do Small FFTs for up to around a half hour, before the pc will shut off and restart, without Orthos throwing an error... though sometimes Orthos will throw an error (the normal rounding error kind). More interestingly, if he takes the side panel off his case, he can go hours without a restart, and the volts on 12v stay about 0.1v higher on Orthos load (11.9v, that is)
I sat down with a volt meter and measured the volts on the 12v rail when he was running Orthos. At idle, there is about 12.05v at the free molex connector we were measuring at. At full Orthos load, his 12v rail volts will hover a bit above 11.8v, with the PSU putting out decidedly warm air, even though his case temp was only couple degrees above ambient.
Oddly, after it restarts, sometimes it will lockup on the POST screen, having detected only 1 of 2 CPU cores.
Personally, I want to suspect a PSU problem, though the idea of a failing CPU keeps nagging. Any ideas are appreciated.
Abit AW8
