Weird Sound
Spark_Plug
I just upgraded my computer the other day and now whenever I try to overclock it, I hear this high pitched screech when I save to CMOS. It doesn't happen when stock. When I increase the FSB to 280 I still get this (thats the lowest I have tried but will try lower). I have no clue why this is happening and when I try to do a search I see no results. My specs are:
Gigabyte P35C-DS3R
Intel Q6600 B3 stepping
4gb Patriot Performance Ram
EVGA 8800GTX
Corsair HX620
Seagate 7200.10 320GB
Thermalright Ultra-120 Extreme with Scythe Sflex F fan.
Can anyone explain what this high pitched sound means and what to do about it?
Thanks.
At 270 it doesn't do it. Someone told me BIOS update, would this fix the problem do you think?
Potentially. There's rarely a good reason to not update your BIOS anyway.
Many boards "screech" at higher FSB -- my 680i makes a noise, but it's not loud and doesn't both me... and only seems to happen at 100% load, like when running Orthos or similar. I can't remember what component people blame this on. If it bothers you enough you could try RMAing the board and hoping the one they replace it with does not make the noise, but they may refuse the request because the board is otherwise functional. It could also be your PSU, potentially, so stick your head in the case and make sure it's the board before you try and do anything about it.
It won't even let me boot when this happens. It just resets it self back to the original 2.4ghz. This is a loud sound that would get very annoying, I don't know how to describe it. It happens right when the system gets powered on, I notice it right when the fans start to rotate.
And your FSB is set to 280? That's not high at all... Hmm. Yes, update your BIOS and if it doesn't go away RMA the board. I doubt it's your PSU, and also doubt it's your CPU. There may be something wrong with the motherboard, but again, update the BIOS before pronouncing it broken.
Well I found out that the noise I was hearing was the PSU, I unplugged the PSU and used me old Antec 550 Watt Truepower and the noise went away, however when I set the FSB to 280 the fans would start up and then restart. Same thing would happen again and then the settings were reset to the defaults.
I ran memtest the other day for 8 hours and got through 10 passes without any errors so I don't think memory is the problem either.
