Weird shutdown issues
OFaceSIG
So I just built the new system in my sig and I'm having the wierdest issue. My system will not completely shutdown. The screens go dark as if in sleep mode but the computer itself will not shut down. Anyone else seeing this? on z77s or this board if you have it?
too me it sounds like a driver issue. I would check to ensure you have updated drivers for your MoBO / chipset.
Yeah before I installed I updated the BIOS and never tried the shipping BIOS. That may have been a mistake. Also there is only one driver out for the 670s current so that could have something to do with it.
Also I downloaded the Intel chipset drivers from Asrock's site and I should have just gotten them from Intel, probably newer ones out. I may just do a fresh build if Intel's drivers are newer and see what happens.
I rebuilt the system with all the latest drivers and still I cannot shut down without holding the power button. I have since tried a different power supply and reverted to the previous version BIOS to no avail. Going to try different ram, then a single gtx670 and then my old 6950s tomorrow. The fix has to be somewhere.
System rebuilt to no avail with the latest drivers. Still will not shut down properly. I figured maybe it's a wierd incompatibiliy with my cheapo Rosewill 1kw power supply. Swapped in a super high end 760w seasonic I got a the FX gameexperience, still no go, will not shut down. Going to try different memory, then a single GTX670 and then my old 6950s and see if it still will not. At that point it's the mobo and asrock owes me a non-lemon.
That's weird. It may be motherboard like you said. Asrock is lower-end Asus basically. Typically, their quality is very good like the parent company.
I have the z77 Extreme4-M board with a single GTX460 and don't have any shutdown problems, but out of curiosity I looked around and found this discussion. I guess you can tell if taking out one of your vid cards fixes the problem.
Yeah after reading this article I'm starting to get real mad. I went Nvidia because the 670 price is incredible and their drivers were supposed to be "top notch." This is very frustrating. And the more I learn about it the more it's appearing to be a pure Nvidia issue.
So I rebuilt my system with just the onboard i5 graphics and onboard realtek audio guess what it's fine. I think it's the nvidia drivers. That's what that thread atomik77 linked seems to suggest. I found a driver on the MSI site (my 670s are MSI) that's older then the one that's on nvidia's site. Going to try those.
Glad you posted this topic, I too am starting to think it's the nVidia drivers. When I was using onboard graphics it was just fine. Then last night I received 2 gigabyte 670's, installed them and installed the nvidia drivers and now my computer is doing the same thing. The only other thing was windows installed some updates. But when I hit shutdown, it turns off monitor but computer and fans are still on.. have to hold the power button to turn it off.
My specs are the following:
Asus P8Z77 V Deluxe
Intel 3570K
Corsair Vengeance 1866 RAM
2 x Gigabyte GTX 670
This thread seems to conclude the problem is caused by Windows handling the 1394 controller in some motherboards and not allowing it to shutdown. Solution was to find the 1394 device in Device Manager and in Power Management, allow it to shut down to save power. There were also a couple a responses saying Windows Firewall was causing the problem, disable it to find out. Neither of these seem to make sense in this situation.
There's a lot of other discussion about SLI causing this, some of which said a different driver fixed the problem. Bad power supply was also a fix for a couple.
I would contact Asrock and Asus for ideas, that would drive me crazy especially on a new build!
I saw that too and didn't work :( It's the nvidia drivers. Going to test out beta drivers when i get home.
@peemonkey This is has been a bullshit journey but I'm glad Nvidia is attemping to address the issue.
However I haven't tried them but the earlier link posted by atomik lead me to this fix:
download the geforce sli profile tool and export your profiles text and I made this change and it works:
*****ORIGINAL TEXT******
Profile "Desktop Windows Manager"
ShowOn GeForce
ProfileType Application
Executable "dwm.exe"
Setting ID_0x1034cb89 = 0x00000000
Setting ID_0x1057eb71 = 0x00000000
EndProfile
******NEW TEXT*******
ShowOn GeForce
EndProfile
After I removed that one hex string my machine shuts down now. Now I would rather the fix be IN the drivers so I'm going to try the beta drivers next. I will update my with my findings.
Ugg worked the first time. 2nd shutdown attempt was a no go. DANG IT. Beta drivers tomorrow.
