Weird SATA power issue...
Brahmzy
Hey all,
So I got my new brand new OEM 74GB 16mb Raptors in.
Right now I ain't got a box to put 'em in, but I at least wanted to plug 'em in to see if they spin up.
So, as you know they have both a new SATA power input and an old legacy 4-pin power input.
Before you say it...NO I did not plug in both types of connections at the same time! :)
The issue I'm having is if I use my Antec NEO's SATA power plugs, both drives spin up fine. If I use a legacy power connector, neither one of them spin up. I can even put a legacy to SATA power adapter on the 4-pin molex and they spin up fine.
It's like unless they are being fed power from the SATA connections, they WILL NOT spin up.
This sucks as I prefer the old 4-pin molex connectors over the new SATA connectors.
Is there maybe a jumper I have to put on to enable the legacy power connection?
Not trying to hot plug 'em. I've read all WD's docs and cannot seem to come to any conclusion. In the mail tomorrow, I get my WD 250GB 16mb SATAII HDD. I will try it and see what happens.
And yes, these molex connectors work for everything else - even the SATA adapter!
No! Apparently this will smoke the drive. It says all over NEVER to connect both types at the same time.
I meant SATA DATA cable.. sorry.
My guess: staggered spinup support. Thus, when you put them on molex, they wait for the go signal from the data cable to start spinning up. Not a real strong guess, but it's something.
I have not tried connecting a SATA dat cable yet as I have no way to do this at the moment. (I will when Conroe gets here)
I was wondering this myself - maybe it does need to see signal on the data cable. That's the only plausible explanation as BOTH drives exhibit the exact same behavior. The chances of getting two half-defective Raptors with serial numbers far apart is very slim.
Maybe you guys are right.
So I plugged in my brand new WD 250GB 16mb SATAII HDD that came in the mail today, and it spins up fine with both the SATA power connector OR the 4-pin molex.
So I have 2 brand new Raptor 74GB 16mb HDDs that will not spin up on the same 4-pin molex.
WTF?
Anybody else have a new 74GB Raptor they can test?
WTF?
I have an old one. If I remember, i will try it tonight, but my raptor is old(er), hence there may be lots to differences.
