Weird Sanyo Denki fan
BeavermanA
I got this fan for cheap on ebay some time ago but never used it cause I thought it might be too loud for my liking. I can't find any info on this specific model, dB, CFM etc. Anyone have any insight? And will this thing even work if I plug it into one of the fan slots on a motherboard?
Well, seeing as its a 120L fan the L stands for the "long life" line, I don't see a 0.7 amp fan in that line right now, so my guess is it's no longer made, over all its a 120mmx38mm fan, being that its 48v and .7amps, my guess is quite high speed and loud, I don't know if the connectors will hook into a header on a mobo, but even if it did there is no telling if it will run, since it is a 48v fan, it all matters on what its start up voltage is as it will be running off of a 12v source.
Thanks for the info.
Why does it look like it's in a die cast metal housing?
The housing is made of metal as far as I can tell without opening it. Very cold to touch and is rather heavy for a fan.
Don't you need to be careful when plugging fans with such high voltage into your motherboard. I could have swore I read somewhere that fan with such a high voltage needs to be plugged into a fan controller.... or I could be completely wrong.
That would be amperage. This one pulls 0.7A, which is pushing it on anything but some Asus boards, that used to advertise 1A per header, dedicated. This fan, at 48V @ .7A, needs almost 34 watts to itself. Compare that to a standard "big" fan, like that Ultra Kaze 3000rpm- 12V @ .6A means 7.2W draw. That's already a loud, violent fan, and this one draws between four and five times the raw power.
lol damn, I think I will leave it alone then. Paid like $4.80 for it with cashback. Maybe I'll hook it up like that guy had it in the vid and stick it in my window at night during the summer.
