bigstusexy
- Jan 28, 2002
Hello, this is windows 2000 pro with this issue.
I have a problem where I can't resolve any of my local computer names, I know everything is set right So while I was checking the ordinary and the not so, I came accross my route table and I saw an entry (I could be wrong on this) that is making all my broadcasts go to no where
I tried to clean up the table a bit for you all to make it easyer to read but nope no can do (argh can we get some pre tags use!). NOW don't think that last route is a typo thats how its stated in my system, I'm thinking that its an error and I wanted to manually remove the route and add it correctly... No go as you can see. Anyone else ever seen this or know whats going on?
Code:
Interface List
0x1 ........................... MS TCP Loopback interface
0x2 ...00 ff e3 e7 96 41 ...... TAP VPN Adapter.
0x1000004 ...00 d0 59 b5 44 76 ...... Intel(R) PRO/100 VE Network Connection
0x1000005 ...00 05 5d 97 8f dc ...... Realtek RTL8180 Wireless LAN (Mini-)PCI NI
C
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.101 1
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
192.168.0.0 255.255.255.0 192.168.0.101 192.168.0.101 1
192.168.0.101 255.255.255.255 127.0.0.1 127.0.0.1 1
192.168.0.255 255.255.255.255 192.168.0.101 192.168.0.101 1
224.0.0.0 224.0.0.0 192.168.0.101 192.168.0.101 1
255.255.255.255 255.255.255.255 192.168.0.101 2 1
Default Gateway: 192.168.0.1
Persistent Routes:
None
C:\Documents and Settings\Administrator>route delete 255.255.255.255 mask 255.25
5.255.255 182.168.0.101
route: bad destination address 255.255.255.255
