Weird Request: Dual Color LED
CptFalcon
I'm looking for a case that has a Dual Color LED.
Example:
On - Green
Sleep - (Blinking) Orange
Off - Off (Obviously)
Essentially it's close to what OEM PC makers have on their own prebuilt towers and laptops where the power led indicator blinks instead of being off.
What cases on the market have a 3 pin connector that allows the mobo to do this?
Thanks in advance
If you're good at wiring, you could do it yourself. I have a pile of tri colour (RGB) LED's, and they have 4 prongs, 3 for colour, and a single ground, so its actually really easy to wire up. Your only issue is finding a motherboard that blinks what you want.
There are dual color LED's out there, either with 2 leads or 3. on the 3 lead ones, you do a common ground, then run one of each to the power on, and sleep if you can find a board to do this.
Could be done on the cheap if you can find a board that actually gives a signal for sleep.
