Ok, I've been using the same setup and it's run great for over a year, until the past few weeks. When I shut the system off for any length of time and go to turn it back on, it won't restart. It will power on, the fans spin up, but when it goes to boot up, it just restarts itself. It will restart over and over again without actually booting. If you pull the plug and manually restart it enough times, you can eventually get it to boot and then it runs great. As long as you don't shut it off, it will run for days without a glitch. In Windows, you can even "Restart" your system and it's fine, but if you "Shutdown" and then manually turn it back on, you're screwed. I haven't added any new hardware to the system in about a year. I tried clearing the CMOS to no avail. Right now, I just leave it running 24/7, but it's driving me nuts. Ideas?
System Specs: Win XP, Abit AI7, Intel P4 3.0 Ghz, 1 GB Corsair DDR, ATI Radeon 9500 PRO, SB Live 5.1, Raptor main HD and a 40 GB Maxtor , Lite-On CD burner and DVD drive in an Antec Sonata case.
Thanks a bunch,
Casefan
Thanks a bunch,
Casefan
