Weird Q6600 Core Temp
Raven88
I am running Prime95 and getting core temps of 57, 57, 51, 49. I know not all core temps are going to be the same, but should I be that far off with the 49?
just to kinda give you a comparision I'm running a q6600 @ 3.2 temps are 48-40-42-45
ok so the random temp that is just way out there is nothing to worrie about then.
I really wouldn't worry that much I've been running this system since august and everythings going great...Just enjoy :)
My OC now is FSB=307, CPU=2763 MHz. I am using Q-Fan to control the CPU fan speed.
According to SpeedFan, CPU idle, CPU=31, Core=40,40,38,38 and the fan is running at 970 RPM.
After running Prime95 for an hour for all 4 cores:
According to SpeedFan, CPU 100%, CPU=47-50, Core1 and Core2 = 58-63, Core3 and Core4 = 54-59. Fan=2250 RPM.
Ok just wanted to make sure nothing was up with the 1 temp being a bit lower then the others.
no temps aren't at full load thesy raise a good 2-4 degrees normally under full load
Even adding 4c to each reading, you still get 52-44-46-49. Very good temp.
My temp are much higher than yours (see my earlier thread).
