Weird problem...
TLJester
After moving my PC (well shipping it accross the Atlantic), I now get artifacts/repeated patterns accross the screen.
Thought maybe the graphics card had got dislodged, but removing/cleaning/replacing didnt help. Same with the memory.
Also tried setting everthing to default settings, with no luck.
However I noticed if I give the case a good whack the patterns change (I tried wiggling the DVI cable, but that didnt do anything).
I have been overclocking this machine for a few years. And have noticed it has become a bit reluctant to start of first press of the ON button. Its also a bit of a cheap system (PSU is one free with the case)
What do you think is happing? Something happend in shipping? or its been overclocked too much? How come banging on it helps? Maybe PSU busted?
Heres the spec
MSI K8N
AMD 3000 s754 (oc 2.2ghz, +3.3%v)
1gb Kingmax DDR Hardcore (i forget speed rating, but they are suppoesed to be high) 1.75v
ATI 9800pro (with Icy cooler job, 9800xt flash, AGP 67mhz)
250gb SATA drive
400w free PSU
Bunch of fans.
nothing else in it!
Any suggestions welcome :D
Forgot to mention that I tried running the system with a very old GeForce 2 card, and though it was better I still got a few specks of artifacts, but not a repeating pattern .
