kill4killin
- Jul 3, 2006
Ok, so as some of you may know, i overclocked my processor a few weeks ago to 3Ghz from the stock 2.2Ghz, however, i backed it down because the amount of voltage that it needed and the amount of heat it was producing was not practical for every day use. So i backed it down to 2.7Ghz noting that, that seemed to be a good compromise of stability and performance.
Well, recently i added a new hard drive and a floppy disk drive to my system and when i started up the computer again, i noticed right off the bat that when it got to the windows logon screen it would imediatly blue screen. Then after i tried a few more times it booted stabily and loged in and then when i would start a program, i would crash the system. I also noted that my temps of my system seem to have changed a lot after the addition of the new components. The weird thing is, is they dropped! Something tells me something in my mobo got messed up somehow or that my PSU isnt adiquate enough anymore to supply the power output that i need.
Can anyone confirm these thoughts or do you have any other ideas as to a cause to this?
