weird problem with mouse randomly turning off and on
karupt
Here is my prolem with my generic cheap Logitech soccer mouse.
Randomly it will just go off and on. When it does, the optical light will shut off, the Windows usb removal sound will play, and 1 second later, it will return to normal, light back on, and usb insertion sound will play :confused: This can happen upto several times a minute, one after another, especially when playing games (heavy mouse movement) or not for hours even.
To add further confusion, when I plugged it into the usb slot on my keyboard, it would also shut off my keyboard, and when windows media player is playing, it pauses that too. :confused: I sense it may be a physical problem with the mouse itself, because when I hold down the cord at the base of the mouse, and move the mouse in the air with my hands, it can also shut off :confused:
I'm thinking of just breaking this thing and buying an expensive new mouse that will help lower my blood pressure :mad::(
It is pretty common for mice to have issues where the wires inside the cord, especially where it enters the mouse break, because they are stranded sometimes they connect sometimes they dont, moving it, will change the status. If its a cheap mouse then ya, just buy a new one. If you love the mouse you can open it up and sometimes replace the cord.
I checked the cord and it is very snugly fit inside.
