Weird problem with asus board
Chris_B
My uncles system has an asus p4p 800x installed in it. Along with a 2.8ghz p4, fx 5200, 1.5 gig of ram and 2 hard drives. The problem is the system seems to restart itself for no reason periodically. He can be typing something in word and the sytem will restart, but for some reason i can run prime 95 for hours on end with no problems. it seems t hapen mainly when the pc is doing next to nothin, yet when its doing something like running a game it seems to do that with no problem. I thought it was a psu issue the original was a noname 400watt, so he got a new case and an antec neo 430 watt psu, i thought that would solve the problem but it still happens. :confused:
Ive tried updating new bios's new drivers , and still it seems to randomly happen. When it gets back into windows it always complanins about a device driver causing the issue despite me having updated them all.
If you're getting something goofy about bad driver installs, I'd actually try a reformat instead of picking through everything else.
Sure, there may be a quick and easy way to fix it, but if he needs it asap, then back stuff up on DVD/CD and reformat that box.
I'm sure it wasn't the answer you wanted to hear, but...um....yea...lol
Im creating a ghost image of the current install (assuming it stays on that long without rebooting) then gonna format in the morning.
The other weird thing about this pc is when the powers turned on at the wall socket, it'll sort of turn on for a second or 2 then shut off till the power button on the case is pressed, always been that way though. :confused:
