Necromancyr
- Mar 29, 2004
Ok, I'm completely baffled by the problem I am having. I have a Western Digital 200gb hard drive on my system that has been working fine since I got it for christmas. All of a suddent it's causing windows to BSOD.
I started getting some weird issues with McAfee Virus Scan autoupdate and I decided I wanted to reinstall XP. So, when I attempted to do so setup started BSOD'ing. So, I unplugged all drives except for my system HDD and my CD-ROM drive that I would install from. Installation went without a hitch. Completed ALL Windows Updates, then began plugging back in drives.
I plug back in the drives, and wind up getting a BSOD (error code STOP 0x0000007f - all of the rest of the line is 0x00000000's) and an instant reboot. (The only way I could get the error code was to try to reinstall XP and see what code came up when that BSOD'd and didnt force a reboot instantly).
My system is an ABit BX-133, and the I've updated the HPT370 controller to 3.351 (the newest version available) so it can recognize the WDD 200gb as a 200gb hard drive. I have a Tualatin (w/adaptor) 1.1ghz celeron in there, NON-OC'd.
Now, what I've done to try to pinpoint the issue is the following:
- Remove drive, XP boots fine. No issues.
- WDD Diagnostics on the drive. No issues reported in both quick and long tests.
- Memtested the computer, no issues.
- Swapped out all memory with drive connected to see if it was some faulty RAM. No alterations.
- Changed IDE cables. No change.
- Put the drive on the primary slave, secondary master, and secondary slave configurations - problem still occurs no matter where it is.
- Disconnected EVERY other drive except for the system drive and this drive. Still BSOD's.
- Tried Cable selected jumper settings. Doesn't even get recognized by the HPT bios when I do this. (BTW, the jumper settings have been correct for each config I've tested).
Any suggestions/ideas would be great. I'd prefer not to RMA, for one big reason: I can't get at the drive. The Abit BX133 can only get at a 200gb HDD through the HPT370 and I've yet to find a way to access the HPT370 via any DOS methods. Add into it that the drive is NTFS, and getting anything off it seems impossible considering I can't get into Windows.
So, after discussing with people in #hardocp for a bit of last nite I put this up as a plea for help to the forums
(Oh, and last thing, I don't have another PC I can put this into to access the entire drive.)
