Weird Problem with 6950
dambrosioj
Hey guys I have a xfx 6950 2gb and I am getting this weird line in Bulletstorm, only other game I have tried is COD and didnt really notice it in that but its an older game.
Has anyone seen this before
And I tried installing the latest drivers from ATI's site and also XFX's site both do the same thing
Does this happen when you use a single monitor?
I read about this on a forum, not sure where. The victim was advised to uninstall all drivers, then run a scruber, setup his computer to use just one monitor then reinstall the desired driver. Test the driver to be sure the issue is no longer occuring. The last thing was to reconnect the other two monitors and setup eyefinity. Alas, the victim did not reply so I have no clue if it worked. Good luck.
Supposedly there is a bug if you run bulletstorm with post process set to high, I'm not sure if this is it. One way to find out, if your post process setting is on high, turn it down to medium and try again. If gone your good to go, until they update the drivers and fix this bug.
Will try that thanks, ya it is on high will try when i get home
