Weird problem, MB I think
Discussion in 'Motherboards' started by Stoly, Jul 9, 2018.
  1. Stoly
    Stoly [H]ardness Supreme
    5,840
    Jul 26, 2005
    I have a Core i7 4770 on a Gibabyte GA-B85M-DS3H. For about a month now, every time I turn it off, or loose power, it won't POST. Sometimes it won't come back from sleep either.
    Fix is random.
    Unplugging the PSU sometimes work
    Removing one of the ram stick (It has 2 8gb modules). I can put back the 2nd module afterwards.
    Moving the ram to different slots.
    Reseating the videocard.
    Removing the CMOS battery.
    Reinstalling the CPU
    All of the above...
    I've tested everything but the mobo/cpu on a different PC and it all works. Also tried different ram modules.
    It all points to the MB IMO but I'd want to rule out the CPU.
    The system is completely stable other than the power up issue.
    Any suggestions?
  2. pendragon1
    pendragon1 [H]ardForum Junkie
    11,475
    Oct 7, 2000
    replace your cmos battery and reset the bios. then try another known good psu.
  3. Stoly
    5,840
    Jul 26, 2005
    Tnx, but done that already.
  4. pendragon1
    11,475
    Oct 7, 2000
    did you test/replace the battery? ive had dying one cause all sorts of weird issues.
  5. Stoly
    5,840
    Jul 26, 2005
    Yes I replaced it with a new one.
    Funny thing. I just turned it on and it post on the 2nd try.
    pendragon1 likes this.
  6. pendragon1
    11,475
    Oct 7, 2000
    everything that isn't needed is disconnected, ext drives, devices etc? tried outside the case?
  7. Stoly
    5,840
    Jul 26, 2005
    All of the above
  8. Av8ing1
    Av8ing1 n00bie
    2
    Apr 10, 2017
    I had a USB device causing issues like that once. Sure you pulled everything?
  9. Meeho
    Meeho 2[H]4U
    3,887
    Aug 16, 2010
    Overclocked?
  10. Stoly
    5,840
    Jul 26, 2005
    Nope nada
  11. Stoly
    5,840
    Jul 26, 2005
    No, I don't think you can OC on a this mobo at all.
  12. Meeho
    Meeho 2[H]4U
    3,887
    Aug 16, 2010
    PSU? Have you tried a different one with this computer?
  13. Stoly
    5,840
    Jul 26, 2005
    I'll have access to an exact same system by the end of the week. Hopefully I can finally check if its the mobo or the CPU.
  14. Stoly
    5,840
    Jul 26, 2005
    Already tried different PSU. It was running on a 500w and now on a 600w Antec.
  15. Meeho
    Meeho 2[H]4U
    3,887
    Aug 16, 2010
    How do the caps on the MBO look?
  16. Stoly
    5,840
    Jul 26, 2005
    I'll check when I get home, but at first sight I didn't find damaged capacitors.
  17. Azrak
    Azrak Gawd
    643
    Oct 4, 2015
    When it won't POST, what does it do? Fans run and it just sits there w/no video?
  18. Stoly
    5,840
    Jul 26, 2005
    Everything is powered up, fans run, no video, no beeping.
    It only beeps if the ram slots are empty.
    Hmmmm... haven't tried disabling onboard video... I won't use it anyway. I'll give it a try later.
  19. pendragon1
    11,475
    Oct 7, 2000
    ^ that's a good idea too. am I understanding correctly that you tested the gpu in another system but not a new gpu in the problem one?
  20. Azrak
    Azrak Gawd
    643
    Oct 4, 2015
    Like pendragon1 above, I was going to ask if it beeped with no video card installed.
    Seems like a timing issue more than anything since randomly swapping stuff doesn't really fix it and it doesn't seem to be a power problem. Since it's stable once running, it's like there is a PCIe initialization problem of some kind during POST.
    Is there a newer BIOS for the video card? What video card is it?
  21. Stoly
    5,840
    Jul 26, 2005
    Don't have to, the problem persists with the integrated video
  22. pendragon1
    11,475
    Oct 7, 2000
    think you've covered it. mobo/cpu next.
  23. Stoly
    5,840
    Jul 26, 2005
    I only recently added the video card for testing. It's a gtx1070ti
  24. Stoly
    5,840
    Jul 26, 2005
    Boot up on first try after disabling the integrated video. Haven't added the 2nd ram stick nor HDDs yet. I'll do some more testing before that.
  25. Stoly
    5,840
    Jul 26, 2005
    Installed hdds and 2nd ram stick.
    So far, so good
  26. Stoly
    5,840
    Jul 26, 2005
    Ok, so I reactivated integrated video and its still working... hmmm I guess I can't complain
  27. pendragon1
    11,475
    Oct 7, 2000
    it just wanted some attention. glad its working.
  28. Stoly
    5,840
    Jul 26, 2005
    yeah probably :):)
