Weird Problem Booting Up
RLich8
I have an Asus P5N-E SLI motherboard. Whenever I power up my machine, I always have to attempt 3 times. It always powers up on the 3rd.
The 1st time it hangs at the initial screen and says F8 for Boot Menu, DEL to Boot (or something like that), the 2nd time it seems like it's booting but it hangs at a black screen, and then the 3rd time it finally boots.
I'm thinking it's something with the motherboard, maybe I need to reflash to a newer bios or something?
Specs are in my sig if you need them.
Thanks
Well usually that means your hardrive is going to die soon. I seen it happen several times on other machines. Have you tried swapping it?
Alright, well, good. I'm just about to buy new drives. My boot drive doesn't mean shit to me. It's my secondary storage drive which I have all the precious goods on, so I should be okay.
