Weird P5WDHDlx problem (USB)
thenickmix
Ok, I have a Logitech G15 and G5. Whenever I reboot my computer, they won't work. In fact, no USB devices will work. So I have to restart with a PS/2 keyboard, and then I navigate into control panel and uninstall the USB2 driver from device manager. It then automatically reinstalls itself and everything works. I have to do this every time the computer reboots. Anyone know what the heck is going on?
You should have the option in setup to set the USB keyboard affinity to BIOS rather than operating system. That should fix it, though I don't know why it would be dropping out like that.
That's odd. I have a G15 and a G7 and I have no problems at all with the same board. Are you by chance using the USB ports that the remote control is supposed to occupy?
