weird OC performance
Swamp
Heres my problems
I have a i5 750 EVGA p55 SLI mobo. RIPJAW Gskill ram 9-9-9-24. Watercooling
This is my problem. At stock speeds windows boots up fast, everything loads really quick. I click to open programs and it opens them instantly.
As soon as I overclock past 3.2ghz. For windows stuff. opening stuff. Its slow. I have tried messing with everything, i dont get it. Benchmarks are faster the higher i OC, same with games.
I have speedtest, C state, all that disable.
@4ghz
1.3v
4.27gt/s
ram is at 1600mhz stock speed 1.5v
Anyone else have this problem?
could be that its not completely stable.. may want to try upping the voltage a little bit and see if it gets smoother.. see if that works.. just an idea.. may work may not..
