The set up I have is Verizon Fios wireless router (router 1) and a WRT54G running a DD-WRT in repeater mode (Router 2). Router 1 is both wireless and wired, but router 2 is only wireless and has no wires.
I had it set up in such a way that regardless of which I was connected to, I could access files on my main computer, which is connected only via lan. I started having issues connected to my main computer, couldn't figure out what the problem was. Then I noticed that my main computer was saying it was connected to Router 2, which is impossible since the wireless adapter was disable AND it was connected to the wired router.
I removed the cable from my computer and plugged it into my laptop and shut off the wireless for my laptop. Again, it was reading that it was connected to Router 2 through LAN.
I've reset both routers, factory reset the Verizon Router, shut off Router 2 and tried using router 1 only, updated drivers, /flushdns on both computers. I haven't touched the routers in the past few days. Both of these computers were recently formatted. I had just installed Avast on both computers, and this problem still happens after uninstalling.
TLDR: My lan cable says I'm connected to the wireless only router, even when wireless is disabled.
EDIT: Now it seems to be affecting the entire house that uses the wired connection.
